bbs.zol.com.cn 中关村在线论坛 - 散热器综合讨论 点击数:158  [搜索] [收藏]
猫头鹰Noctua C-12P 鉴赏与评测
楼主    2008-08-24 17:49:20
noctua
考生[24经验]
文章:1
注册:2007-10-01
INTRODUCTION介绍
Any computer enthusiasts would know the importance of keeping the components inside of a system running cool.  This is especially true if you overclock because once pushing the hardware components to their limits, the resultant heat they generate can cause system instability and in some extreme situations ruin the hardware.  Anyone who messes around with their system will know how crappy the retail processor heatsink is in keeping the temperature of the CPU running low.  The retail Intel heatsink is extremely inefficient in the heat conducting department despite the fact it is running at extremely quiet.  Thus, for those who overclock their system, having an after-market heatsink and fan is pretty much a given in order to achieve that perfect overclocking result.
任何计算机发烧友将知道在一个系统运行中保持零部件的变得凉爽是很重要的。 这特别是针对追求超频玩家来说,他们将一次的发挥硬件极限度, 因为产生的热流会引起系统不稳定和在一些极端形势里毁坏硬件。任何一个会让系统周边产生不良的人都将会知道,保持CPU处理器温度流动时的低温,而市售的散热器,却是那要的没有效能,因此对于那些系统超频或是发烧友,是需要一个完美散热良好的优质散热器。
There is no shortage of good CPU heatsink and fan manufactures and Bjorn3D has the priviledge of reviewing many of them.  Today, we have the latest cooler from Noctua, the NH-C12P, which we will put it through our test to see if this heatsink and fan is worth it to you to shed the $69.90 asking price.
没有好CPU 散热器和风扇产品的短缺,Bjorn3D有评论他们中许多的优先权 今天, 我们选择Noctua NH-C12P,是我们的试验以来最新和凉爽的散热器和风扇,对你是值得的69.90 美元的售价。
Noctua: The Company(猫头鹰公司)
Noctua arises from a cooperation between the Austrian Rascom Computer distribution Ges.m.b.H and the Taiwanese Kolink International Corporation and entertains a development partnership with the Austrian Institute of Heat Transmission and Fan Technology (Österreichisches Institut für Wärmeübertragung und Ventilatorentechnik, ÖIWV). These connections form the key to the achievement of our goal: The partnership with the ÖIWV permits the application of scientific measurement instrumentation, methods of calculation and simulation technology in the R&D process. Rascom's long, customer-oriented experience in developing and distributing sound-optimised high-end products ensures a clear focus on the users' needs. The use of Kolink's advanced manufacturing technology and ultra-modern production plants allows us to efficiently implement our technical edge and provide solutions of the highest standard in quality and performance.
Noctua起源于在奥地利Rascom Computer distribution Ges.m.b.和台湾Kolink 多国合作和招待与奥地利热输送和爱好者技术sterreichisches Institut fü;r Wärmeü;bertragung und VentilatorentechnikÖIWV)的研究所一起的一发展合作 . 这些连接形成我们的目标的实现的关键: ÖIWV的合作在R D 过程里允许科学测量器械操作,计算和模拟技术的方法的应用。 Rascom的长,面向用户的在发展和分配声音乐观的高档的产品过程中的经验保证一清楚的集中于用户的需要。Kolink 的先进制造业的技术的使用和超现代的生产厂让我们有效率地实现我们的技术上边缘而且提供质量和表现中最高的标准的解决办法
What does Noctua mean?猫头鹰的定义
The little owl, Athene noctua, is the symbol of the Greek goddess Athene, who represents wisdom, science and strategy. She has a marked preference for the most clever among the Greek heroes, like Odysseus, who endure their adventures by the use of savvy consideration instead of mere force. Noctua
小猫头鹰,阿西妮noctua,是希腊女神阿西妮的象征,描述智慧,科学和策略。 在希腊英雄中她有一个显著的的最聪明的的优先权,比如奥德修斯, 通过使用专门技能考虑忍受他们的冒险而不是仅仅力量。
PACKAGING包装
Noctua packages their cooler in a huge box.  You get a clear view of the heatsink and fan on the front and various information about the heatsink, such as the dimensions of the heatsink, its features and installation process can be found on the outside of the box.  I am particularly glad to see the dimension information on the box as it offers potential buyers an idea of the heatsink’s size so they can assess whether or not the heatsink will fit inside their system. Noctua 在一个极大的盒子中包装他们的冷却器。你可以清楚的看到风扇以及散热器的尺寸, 它的特征的各种不同的资讯和安装程序都清楚的标识在那盒子的外面。  它提供任何一个买主对此散热器清楚详细的参数,清楚了解该散热气是否将会适合他们的系统。
Opening up the box, and you will see that the heatsink and fan is being protected by a cutout of the cardboard against any bumps and potential mistreatement during shipping.  The accessories are placed inside another box, separated from the heatsink and fan, so they won’t get damaged and will not damage the heatsink.  Noctua’s packaging of the NH-C12P ensures that the unit will arrive at your door step will be in working order the moment you open it up. 打开箱子, 并且你将看见散热器和风扇包装预防任何撞击或在在装运期间的发生潜在的损坏内层多一层纸盒的加强保护。 附件被在另一个箱子里面放置,与散热器和风扇分离,将不损坏散热器。 Noctua NH-C12P的包装的保证使用者打开后可以直接正常安装使用它。
   转速不在快,1300RPM就行. 风量不在大,92.3 m³/h就行. 噪音不在低,12.6dB(A)就行. 斯是风扇,唯noctua最牛.
1 楼    2008-08-24 18:31:56
hj2mx
探花[1649经验]探花[1649经验]
文章:28
注册:2007-07-06
对 楼主 noctua 说:
猫头鹰的风扇除了看看以外还是只能看看~
   人的本性便是如此,时间使一切都难以挽留,过去只成回忆,将来才值得期待,我们所能抓住的,只有现在,只有在我手里,怀里,笑里,泪里,因为哪怕是一迟疑间,这故事就换了频道,你我也不再是主角了。
2 楼    2008-08-24 22:09:14
单眼皮青蛙
[散热器综合讨论]版主
九品[14962经验]九品[14962经验]
文章:1527
注册:2005-03-04
对 楼主 noctua 说:
看个评测太费劲了 英文都比汉字大
   简约 简单 随性 随和 自在 自由 关心 关爱 宽宏 宽容 坦然 淡然
3 楼    2008-08-25 22:27:49
三间画屋
[散热器综合讨论]版主
帮派:天涯海阁
八品[45330经验]八品[45330经验]八品[45330经验]
文章:436
注册:2006-11-20
这个东西竟然卖到弹尽粮绝.........
4 楼    2008-08-30 11:58:54
京城流浪汉
[家居装饰][散热器综合讨论]版主
状元[7237经验]状元[7237经验]状元[7237经验]状元[7237经验]
文章:256
注册:2007-06-05
很强大的文章
  群号:60546122欢迎你的加入散热区域专用~请自觉更改ZOL昵称 多谢合作~流浪老汉群欢迎你。。本群讨论散热水冷OC方面的。
5 楼    2008-08-30 14:27:41
arcueid
探花[2441经验]探花[2441经验]
文章:77
注册:2006-02-07
顶一下,很喜欢猫头鹰的东西,就是没米啊。。。
6 楼    2008-08-31 02:48:04
通城虎
[DIY配件]大版版主
帮派:硬件帮
七品[87289经验]七品[87289经验]七品[87289经验]七品[87289经验]
文章:5297
注册:2005-10-27
我是外行,头回听说
  许家有女初长成
7 楼    2008-10-12 19:50:35
kayi
举人[207经验]举人[207经验]举人[207经验]
文章:3
注册:2007-05-23
对 3楼 三间画屋 说:
外来的和尚会念经···
8 楼    2008-10-20 12:13:41
52aa
亚员[832经验]
文章:44
注册:2007-11-05
真的不够经济
·女人之间的那点秘密
·老国有企业照片实拍,A烧原创
·有啊发起午间购活动 “秒杀”白领人群
·51.com大规模撤下彩虹QQ广告 避谈下一
·我也想买魅族M8
·明天,谁将是硬件的主角?
·魅族M8领衔 能让你放弃iPhone的手机荐
·超值尾货更诱人 6990元高配版X61评测
·攒机堪比囤白菜 年末配电脑如何选CPU
·整合乱战/Intel换代 芯片组08全年回顾
·差价200元该选谁? 22宽屏对决28宽屏
废品利用旧电源改水冷排
空心铜住是技术还是偷工减料?
又一新泵 芯睿SC-600水冷循环泵
散热谁王道? 浅谈PC主流散热设备
请问我的CPU温度正常么?
浓郁DIY元素 超频三珊瑚海再玩新花样
强强对决之 GX-03 VS G-751 ~~~
求助求助关于水冷问题!!
硅脂连接热管,散热好吗??
DIY显卡核心+显存水冷散热
M8代言人诞生
M8代言人诞生
网友喜爱的笔记本
网友喜爱的笔记本
最喜爱的十大手机
最喜爱的十大手机
