if this is the first time you've seen this stop error screen appears again ,follow these steps:check to make sure any hardware or software is properly installed ,if this is a new installstion ask yourhardware or software manufctarer for any windows if problems continus,distable or remove any newly installed handware or software Disable BIOS memory options such as caching or shadowing if you need to use safe mode remove or disable components ,restart your computer press F8 to seleet Advanced starty options and then select safe mode Technical information: ***stop:0x0000000A (0x00013602,0x00000002,0x00000000,0x804DCE7B)
