bbs.zol.com.cn 中关村在线论坛 - 声卡讨论 点击数:29  [搜索] [收藏]
[技巧]Ubuntu Linux系统下声卡独占的解决方法
楼主    2008-06-07 12:35:08
梦里的风
[声卡讨论]版主
帮派:潇湘居
武信骑尉(正七品)武信骑尉(正七品)武信骑尉(正七品)
文章:1037
注册:2007-06-21
A much better way of getting esd to work with non-esd-aware apps is to make alsa use its software mixer.
让alsa用它自己的软件混合器一个更好的方法来让esd和不是esd识别的应用程序在一起工作
$ sudo /etc/init.d/alsa-utils stop $ sudo gedit /var/lib/alsa/asound.state
(add the following text verbatim to the start of this file)
$ sudo /etc/init.d/alsa-utils start
# This text should be added to the beginning of
# /var/lib/alsa/asound.state. You only need to add
# it once -- it is saved across reboots.
pcm.asymed {
type asym
playback.pcm dmix
capture.pcm dsnoop
pcm.default {
type plug
slave.pcm asymed
pcm.dmix {
type dmix
ipc_key 5678293
ipc_key_add_uid yes
slave {
pcm 'hw:0,0'
period_time 0
period_size 128
buffer_size 2048
format S16_LE
rate 48000
pcm.dsnoop {
type dsnoop
ipc_key 5778293
ipc_key_add_uid yes
slave {
pcm 'hw:0,0'
period_time 0
period_size 128
buffer_size 2048
format S16_LE
rate 48000
Now as many programs as you want can all use the sound card simultaneously, both the output and the microphone! ESD-aware apps can use ESD, other apps will still work fine.
现在,你可以让你想要的软件全部同时使用声卡, 不管是输出还是和麦克风!ESD识别的应用程序可以使用ESD,另外的应用程序也一样可以正常工作.
One notable misfeature of ESD is that it often ruins the A/V sync when playing videos. After setting up the software mixer, you might find it useful to turn esd off altogether (in tthe Sound control panel uncheck "Enable Software Mixing"). Now, especially with GStreamer 0.10, your movies should have perfect A/V sync.
一个ESD很显着的不好的特性就是在播放视频的时候它会破坏在音频与视频的同步.在设定好软件混合器以後, 你可能会发觉把esd关闭会有些帮助(在音频控制面板里边反选"开启software mixing'). 现在, 特别是在GStreamer 0.10下, 你的电影应该不会有音频和视频不同步发生了. It's a shame that software mixing isn't enabled on Ubuntu by default. software mixing在ubuntu的预设里边不是开启的.
按照这个设置好之后并没有马上生效。
1 楼    2008-06-07 13:18:07
热心的小鸟
文章:102
注册:2008-02-27
看的眼晕!不熟悉的领域
   学习来了。出错不要打我。 QQ925747017
2 楼    2008-06-07 13:18:37
赝品专家
文章:5
注册:2007-01-18
考我外语,不及格.
  等我中大奖了,一定把845的主板换成945的
3 楼    2008-06-07 14:28:14
梦里的风
[声卡讨论]版主
帮派:潇湘居
文章:1037
注册:2007-06-21
对 2楼 赝品专家 说:
这是中英对照的,^_^
4 楼    2008-07-01 23:57:50
athx
文章:2
注册:2006-09-28
怎么不管用啊,ubuntu 8.04 开rhythmbox播放器,声卡还是被占了,其他程序不能用.
328元杀软免费拿
328元杀软免费拿
·微星MOC2008超频训练营参与疯狂抢报中
·招聘助理两名和博客管理员一名
·国庆晒宝:工作中.......
·【原创】微软Vista“降级”延期的真实
·征文:感谢啊!朋友们的支持!
·Windows Server 2008简体中文免激活免
·男生玩机背着点 让女友吃醋的手机一览
·5799至5999元 六款热门独显本对比评析
·65nm酷睿2清仓降价 AMD入门双核跌不停
·790GX还是太贵 3款不足400元780G推荐
·京东大卖AOC次品液晶 消费者大吐苦水
每日一贴(乌龟海岸8830)
声音效果不错,聊天室的人都说好
都说音质,怎么没人说听感?
创新X-Fi Music比拼X-Fi XtremeGamer
最近准备买套箱子 高手给推荐一下
声卡驱动 大半个国家都没有 你有吗
sb audigy 0090 vista着急啊.
玲珑3 剧场版 试听,差强人意!!!
谁有戴尔版Sb0460的驱动吗
大家帮我看看哪个声卡好一些
1999元笔记本上市
1999元笔记本上市
诺基亚触摸屏手机
诺基亚触摸屏手机
十一DIY装机宝典
十一DIY装机宝典
手机“全方位”导购
手机“全方位”导购
