计算机英文术语完全介绍 1、CPU 3DNow!(3D no waiting) ALU(Arithmetic Logic Unit,算术逻辑单元) AGU(Address Generation Units,地址产成单元) BGA(Ball Grid Array,球状矩阵排列) BHT(branch prediction table,分支预测表) BPU(Branch Processing Unit,分支处理单元) Brach Pediction(分支预测) CMOS(Complementary Metal Oxide Semiconductor,互补金属氧化物半导体) CISC(Complex Instruction Set Computing,复杂指令集计算机) CLK(Clock Cycle,时钟周期) COB(Cache on board,板上集成缓存) COD(Cache on Die,芯片内集成缓存) CPGA(Ceramic Pin Grid Array,陶瓷针型栅格数组) CPU(Center Processing Unit,中央处理器) Data Forwarding(数据前送) Decode(指令译码) DIB(Dual Independent Bus,双独立总线) EC(Embedded Controller,嵌入式控制器) Embedded Chips(嵌入式处理器) EPIC(explicitly parallel instruction code,并行指令代码) FADD(Floationg Point Addition,浮点加) FCPGA(Flip Chip Pin Grid Array,反转芯片针脚栅格数组) FDIV(Floationg Point Divide,浮点除) FEMMS(Fast Entry/Exit Multimedia State,快速进入/退出多媒体状态) FFT(fast Fourier transform,快速热奥姆转换) FID(FID:Frequency identify,频率鉴别号码) FIFO(First Input First Output,先入先出队列) flip-chip(芯片反转) FLOP(Floating Point Operations Per Second,浮点操作/秒) FMUL(Floationg Point Multiplication,浮点乘) FPU(Float Point Unit,浮点运算单元) FSUB(Floationg Point Subtraction,浮点减) HL-PBGA(表面黏着,高耐热、轻薄型塑料球状矩阵封装) IA(Intel Architecture,英特尔架构) ICU(Instruction Control Unit,指令控制单元) ID(identify,鉴别号码) IDF(Intel Developer Forum,英特尔开发者论坛) IEU(Integer Execution Units,整数执行单元) IMM(Intel Mobile Module,英特尔移动模块) Instructions Cache(指令缓存) Instruction Coloring(指令分类) IPC(Instructions Per Clock Cycle,指令/时钟周期) ISA(instruction set architecture,指令集架构) KNI(Katmai New Instructions,Katmai新指令集,即SSE) Latency(潜伏期) LDT(Lightning Data Transport,闪电数据传输总线) Local Interconnect(局域互连) MESI(Modified,Exclusive,Shared,Invalid:修改、排除、共享、废弃) MMX(MultiMedia Extensions,多媒体扩展指令集) MMU(Multimedia Unit,多媒体单元) MFLOPS(Million Floationg Point/Second,每秒百万个浮点操作) MHz(Million Hertz,兆赫兹) MP(Multi-Processing,多重处理器架构) MPS(MultiProcessor Specification,多重处理器规范) MSRs(Model-Specific Registers,特别模块寄存器) NAOC(no-account OverClock,无效超频) NI(Non-Intel,非英特尔) OLGA(Organic Land Grid Array,基板栅格数组) OoO(Out of Order,乱序执行) PGA(Pin-Grid Array,引脚网格数组,耗电大) PR(Performance Rate,性能比率) PSN(Processor Serial numbers,处理器序列号) PIB(Processor In a Box,盒装处理器) PPGA(Plastic Pin Grid Array,塑料针状矩阵封装) PQFP(Plastic Quad Flat Package,塑料方块平面封装) RAW(Read after Write,写后读) Register Contention(抢占寄存器) Register Pressure(寄存器不足) Register Renaming(寄存器重命名) Remark(芯片频率重标识) Resource contention(资源冲突) Retirement(指令引退) RISC(Reduced Instruction Set Computing,精简指令集计算机) SEC(Single Edge Connector,单边连接器) Shallow-trench isolation(浅槽隔离) SIMD(Single Instruction Multiple Data,单指令多数据流) SiO2F(Fluorided Silicon Oxide,二氧氟化硅) SMI(System Management Interrupt,系统管理中断) SMM(System Management Mode,系统管理模式) SMP(Symmetric Multi-Processing,对称式多重处理架构) SOI(Silicon-on-insulator,绝缘体硅片) SONC(System on a chip,系统集成芯片) SPEC(System Performance Evaluation Corporation,系统性能评估测试) SQRT(Square Root Calculations,平方根计算) SSE(Streaming SIMD Extensions,单一指令多数据流扩展) Superscalar(超标量体系结构) TCP(Tape Carrier Package,薄膜封装,发热小) Throughput(吞吐量) TLB(Translate Look side Buffers,翻译旁视缓冲器) USWC(Uncacheabled Speculative Write Combination,无缓冲随机联合写操作) VALU(Vector Arithmetic Logic Unit,向量算术逻辑单元) VLIW(Very Long Instruction Word,超长指令字) VPU(Vector Permutate Unit,向量排列单元) VPU(vector processing units,向量处理单元,即处理MMX、SSE等SIMD指令的地方)
2、主板 ADIMM(advanced Dual In-line Memory Modules,高级双重内嵌式内存模块) AMR(Audio/Modem Riser;音效/调制解调器主机板附加直立插卡) AHA(Accelerated Hub Architecture,加速中心架构) ASK IR(Amplitude Shift Keyed Infra-Red,长波形可移动输入红外线) ATX(AT Extend,扩展型AT) BIOS(Basic Input/Output System,基本输入/输出系统) CSE(Configuration Space Enable,可分配空间) DB(Device Bay,设备插架) DMI(Desktop Management Interface,桌面管理接口) EB(Expansion Bus,扩展总线) EISA(Enhanced Industry Standard Architecture,增强形工业标准架构) EMI(Electromagnetic Interference,电磁干扰) ESCD(Extended System Configuration Data,可扩展系统配置数据) FBC(Frame Buffer Cache,帧缓冲缓存) FireWire(火线,即IEEE1394标准) FSB(Front Side Bus,前置总线,即外部总线) FWH( Firmware Hub,固件中心) GMCH(Graphics & Memory Controller Hub,图形和内存控制中心) GPIs(General Purpose Inputs,普通操作输入) ICH(Input/Output Controller Hub,输入/输出控制中心) IR(infrared ray,红外线) IrDA(infrared ray,红外线通信接口可进行局域网存取和档共享) ISA(Industry Standard Architecture,工业标准架构) ISA(instruction set architecture,工业设置架构) MDC(Mobile Daughter Card,移动式子卡) MRH-R(Memory Repeater Hub,内存数据处理中心) MRH-S(SDRAM Repeater Hub,SDRAM数据处理中心) MTH(Memory Transfer Hub,内存转换中心) NGIO(Next Generation Input/Output,新一代输入/输出标准) P64H(64-bit PCI Controller Hub,64位PCI控制中心) PCB(printed circuit board,印刷电路板) PCBA(Printed Circuit Board Assembly,印刷电路板装配) PCI(Peripheral Component Interconnect,互连外围设备) PCI SIG(Peripheral Component Interconnect Special Interest Group,互连外围设备专业组) POST(Power On Self Test,加电自测试) RNG(Random number Generator,随机数字发生器) RTC(Real Time Clock,实时时钟) KBC(KeyBroad Control,键盘控制器) SBA(Side Band Addressing,边带寻址) SMA(Share Memory Architecture,共享内存结构) STD(Suspend To Disk,磁盘唤醒) STR(Suspend To RAM,内存唤醒) SVR(Switching Voltage Regulator,交换式电压调节) USB(Universal Serial Bus,通用串行总线) USDM(Unified System Diagnostic Manager,统一系统监测管理器) VID(Voltage Identification Definition,电压识别认证) VRM (Voltage Regulator Module,电压调整模块) ZIF(Zero Insertion Force,零插力)
主板技术 技嘉 ACOPS: Automatic CPU OverHeat Prevention System(CPU过热预防系统) SIV: System Information Viewer(系统信息观察) 盘英 ESDJ(Easy Setting Dual Jumper,简化CPU双重跳线法) 浩鑫 UPT(USB、PANEL、LINK、TV-OUT四重界面)
芯片组 ACPI(Advanced Configuration and Power Interface,先进设置和电源管理) AGP(Accelerated Graphics Port,图形加速接口) I/O(Input/Output,输入/输出) MIOC(Memory and I/O Bridge Controller,内存和I/O桥控制器) NBC(North Bridge Chip,北桥芯片) PIIX(PCI ISA/IDE Accelerator,加速器) PSE36(Page Size Extension 36-bit,36位页面尺寸扩展模式) PXB(PCI Expander Bridge,PCI增强桥) RCG(RAS/CAS Generator,RAS/CAS发生器) SBC(South Bridge Chip,南桥芯片) SMB(System Management Bus,全系统管理总线) SPD(Serial Presence Detect,内存内部序号检测装置) SSB(Super South Bridge,超级南桥芯片) TDP(Triton Data Path,数据路径) TSC(Triton System Controller,系统控制器) QPA(Quad Port Acceleration,四界面加速)
3、显示设备 ASIC(Application Specific Integrated Circuit,特殊应用集成电路) ASC(Auto-Sizing and Centering,自动调效屏幕尺寸和中心位置) BLA(Bearn Landing Area,电子束落区) CRC(Cyclical Redundancy Check,循环冗余检查) CRT(Cathode Ray Tube,阴极射线管) DDC(Display Data Channel,显示数据信道) DFL(Dynamic Focus Lens,动态聚焦) DFS(Digital Flex Scan,数字伸缩扫描) DIC(Digital Image Control,数字图像控制) Digital Multiscan II(数字式智能多频追踪) DLP(digital Light Processing,数字光处理) DOSD(Digital On Screen Display,同屏数字化显示) DPMS(Display Power Management Signalling,显示能源管理信号) DQL(Dynamic Quadrapole Lens,动态四极镜) DSP(Digital Signal Processing,数字信号处理) EFEAL(Extended Field Elliptical Aperture Lens,可扩展扫描椭圆孔镜头) FRC(Frame Rate Control,帧比率控制) LCD(liquid crystal display,液晶显示屏) LCOS(Liquid Crystal On Silicon,硅上液晶) LED(light emitting diode,光学二级管) L-SAGIC(Low Power-Small Aperture G1 wiht Impregnated Cathode,低电压光圈阴极管) LVDS(Low Voltage Differential Signal,低电压差动信号) MALS(Multi Astigmatism Lens System,多重散光聚焦系统) MDA(Monochrome Adapter,单色设备) MS(Magnetic Sensors,磁场感应器) Porous Tungsten(活性钨) RSDS(Reduced Swing Differential Signal,小幅度摆动差动信号) Shadow Mask(阴罩式) TDT(Timeing Detection Table,资料测定表) TICRG(Tungsten Impregnated Cathode Ray Gun,钨传输阴级射线枪) TFT(thin film transistor,薄膜晶体管) VAGP(Variable Aperature Grille Pitch,可变间距光栅) VBI(Vertical Blanking Interval,垂直空白间隙) VDT(Video Display Terminals,视频显示终端) VRR(Vertical Refresh Rate,垂直扫描频率)
4、视频 3D(Three Dimensional,三维) 3DS(3D SubSystem,三维子系统) AE(Atmospheric Effects,雾化效果) AFR(Alternate Frame Rendering,交替渲染技术) Anisotropic Filtering(各向异性过滤) APPE(Advanced Packet Parsing Engine,增强形帧解析引擎) AV(Analog Video,模拟视频) Back Buffer(后置缓冲) Backface culling(隐面消除) Battle for Eyeballs(眼球大战,各3D图形芯片公司为了争夺用户而作的竞争) Bilinear Filtering(双线性过滤) CG(Computer Graphics,计算机生成图像) Clipping(剪贴纹理) Clock Synthesizer(时钟合成器) compressed textures(压缩纹理) Concurrent Command Engine(协作命令引擎) Center Processing Unit Utilization(中央处理器占用率) DAC(Digital to Analog Converter,数模传换器) Decal(印花法,用于生成一些半透明效果,如:鲜血飞溅的场面) DFP(Digital Flat Panel,数字式平面显示器) DFS: Dynamic Flat Shading(动态平面描影,可用作加速) Dithering(抖动) Directional Light(方向性光源) DME: Direct Memory Execute(直接内存执行) DOF(Depth of Field,多重境深) dot texture blending(点型纹理混和) Double Buffering(双缓冲区) DIR(Direct Rendering Infrastructure,基层直接渲染) DVI(Digital Video Interface,数字视频接口) DxR(DynamicXTended Resolution,动态可扩展分辨率) DXTC(Direct X Texture Compress,DirectX纹理压缩,以S3TC为基础) Dynamic Z-buffering(动态Z轴缓冲区),显示物体远近,可用作远景 E-DDC(Enhanced Display Data Channel,增强形视频数据信道协议,定义了显示输出与主系统之间的通讯信道,能提高显示输出的画面质量) Edge Anti-aliasing(边缘抗锯齿失真) E-EDID(Enhanced Extended Identification Data,增强形扩充身份辨识数据,定义了计算机通讯视频主系统的数据格式) Execute Buffers(执行缓冲区) environment mapped bump mapping(环境凹凸映射) Extended Burst Transactions(增强式突发处理) Front Buffer(前置缓冲) Flat(平面描影) Frames rate is King(帧数为王) FSAA(Full Scene Anti-aliasing,全景抗锯齿失真) Fog(雾化效果) flip double buffered(反转双缓存) fog table quality(雾化表画质) GART(Graphic Address Remappng Table,图形地址重绘表) Gouraud Shading(高洛德描影,也称为内插法均匀涂色) GPU(Graphics Processing Unit,图形处理器) GTF(Generalized Timing Formula,一般程序时间,定义了产生画面所需要的时间,包括了诸如画面刷新率等) HAL(Hardware Abstraction Layer,硬件抽像化层) hardware motion compensation(硬件运动补偿) HDTV(high definition television,高清晰度电视) HEL: Hardware Emulation Layer(硬件模拟层) high triangle count(复杂三角形计数) ICD(Installable Client Driver,可安装客户端驱动程序) IDCT(Inverse Discrete Cosine Transform,非连续反余弦变换,GeForce的DVD硬件强化技术) Immediate Mode(直接模式) IPPR(Image Processing and Pattern Recognition,图像处理和模式识别) large textures(大型纹理) LF(Linear Filtering,线性过滤,即双线性过滤) lighting(光源) Local Peripheral Bus(局域边缘总线) mipmapping(MIP映射) Modulate(调制混合) Motion Compensation(动态补偿) motion blur(动态模糊) MPPS(Million Pixels Per Second,百万个像素/秒) Multi-Resolution Mesh(多重分辨率组合) Multi Threaded Bus Master(多重主控) Multitexture(多重纹理) nerest Mipmap(邻近MIP映射,又叫点采样技术) Overdraw(透支,全景渲染造成的浪费) partial texture downloads(并行纹理传输) Parallel Processing Perspective Engine(平行透视处理器) PC(Perspective Correction,透视纠正) PGC(Parallel Graphics Configuration,并行图像设置) pixel(P像素,屏幕上的像素点) point light(一般点光源) point sampling(点采样技术,又叫邻近MIP映射) Precise Pixel Interpolation(精确像素插值) Procedural textures(可编程纹理) RAMDAC(Random Access Memory Digital to Analog Converter,随机内存数/模转换器) Reflection mapping(反射贴图) render(着色或渲染) S3(Sight、Sound、Speed,视频、音频、速度) S3TC(S3 Texture Compress,S3纹理压缩,仅支持S3显卡) S3TL(S3 Transformation & Lighting,S3多边形转换和光源处理) Screen Buffer(屏幕缓冲) SDTV(Standard Definition Television,标准清晰度电视) Shading(描影) Single Pass Multi-Texturing(单通道多纹理) SLI(Scanline Interleave,扫描线间插,3Dfx的双Voodoo 2配合技术) Smart Filter(智能过滤) soft shadows(柔和阴影) soft reflections(柔和反射) spot light(小型点光源) SRA(Symmetric Rendering Architecture,对称渲染架构) Stencil Buffers(范本缓冲) Stream Processor(流线处理) SuperScaler Rendering(超标量渲染) texel(T像素,纹理上的像素点) Texture Fidelity(纹理真实性) texture swapping(纹理交换) T&L(Transform and Lighting,多边形转换与光源处理) T-Buffer(T缓冲,3dfx Voodoo4的特效,包括全景反锯齿Full-scene Anti-Aliasing、动态模糊Motion Blur、焦点模糊Depth of Field Blur、柔和阴影Soft Shadows、柔和反射Soft Reflections) TCA(Twin Cache Architecture,双缓存结构) Transparency(透明状效果) Transformation(三角形转换) Trilinear Filtering(三线性过滤) Texture Modes(材质模式) TMIPM(Trilinear MIP Mapping,三次线性MIP材质贴图) UMA(Unified Memory Architecture,统一内存架构) Visualize Geometry Engine(可视化几何引擎) Vertical Interpolation(垂直调变) VIP(Video Interface Port,视频接口) ViRGE(Video and Rendering Graphics Engine,视频描写图形引擎) Voxel(Volume pixels,立体像素,Novalogic的技术) VQTC(Vector-Quantization Texture Compression,向量纹理压缩) VSIS(Video Signal Standard,视频信号标准) v-sync(同步刷新) Z Buffer(Z缓存)
5、音频 3DPA(3D Positional Audio,3D定位音频) AC(Audio Codec,音频多媒体数字信号编译码器) Auxiliary Input(辅助输入接口) CS(Channel Separation,声道分离) DS3D(DirectSound 3D Streams) DSD(Direct Stream Digital,直接数字信号流) DSL(Down Loadable Sample,可下载的取样音色) DLS-2(Downloadable Sounds Level 2,第二代可下载音色) EAX(Environmental Audio Extensions,环境音效扩展技术) FM(Frequency Modulation,频率调制) FR(Frequence Response,频率响应) FSE(Frequency Shifter Effect,频率转换效果) HRTF(Head Related Transfer Function,头部关联传输功能) IAS(Interactive Around-Sound,交互式环绕声) MIDI(Musical Instrument Digital Interface,乐器数字接口) NDA(non-DWORD-aligned ,非DWORD排列) Raw PCM: Raw Pulse Code Modulated(元脉码调制) RMA(RealMedia Architecture,实媒体架构) RTSP(Real Time Streaming Protocol,实时流协议) SACD(Super Audio CD,超级音乐CD) SNR(Signal to Noise Ratio,信噪比) S/PDIF(Sony/Phillips Digital Interface,索尼/飞利普数字接口) SRS(Sound Retrieval System,声音修复系统) Super Intelligent Sound ASIC(超级智慧音频集成电路) THD+N(Total Harmonic Distortion plus Noise,总谐波失真加噪音) QEM(QSound Environmental Modeling,QSound环境建模) WG(Wave Guide,波导合成) WT(Wave Table,波表合成)
6、RAM&ROM ABP(Address Bit Permuting,地址位序列改变) ATC(Access Time from Clock,时钟存取时间) BSRAM(Burst pipelined synchronous static RAM,突发式管道同步静态内存) CAS(Column Address Strobe,列地址控制器) CCT(Clock Cycle Time,时钟周期) DB(Deep Buffer,深度缓冲) DDR SDRAM(Double Date Rate,双数据率SDRAM) DIL(dual-in-line) DIMM(Dual In-line Memory Modules,双重内嵌式内存模块) DRAM(Dynamic Random Access Memory,动态随机内存) DRDRAM(Direct RAMbus DRAM,直接RAMbus内存) ECC(Error Checking and Correction,错误检查修正) EEPROM(Electrically Erasable Programmable ROM,电擦写可编程只读存储器) FM(Flash Memory,闪存) FMD ROM (Fluorescent Material Read Only Memory,荧光质只读存储器) PIROM(Processor Information ROM,处理器信息ROM) PLEDM(Phase-state Low Electron(hole)-number Drive Memory) RAC(Rambus Asic Cell,Rambus集成电路单元) RAS(Row Address Strobe,行地址控制器) RDRAM(Rambus Direct RAM,直接型RambusRAM) DIMM(RAMBUS In-line Memory Modules,RAMBUS内嵌式内存模块) SDR SDRAM(Single Date Rate,单数据率SDRAM) SGRAM(synchronous graphics RAM,同步图形随机储存器) SO-DIMM(Small Outline Dual In-line Memory Modules,小型双重内嵌式内存模块) SPD(Serial Presence Detect,串行存在检查) SRAM(Static Random Access Memory,静态随机内存) SSTL-2(Stub Series Terminated Logic-2) TSOPs(thin small outline packages,超小型封装) USWV(Uncacheable,Speculative,Write-Combining非缓冲随机混合写入) VCMA(Virtual Channel Memory architecture,虚拟信道内存结构)
7、磁盘 AAT(Average access time,平均存取时间) ABS(Auto Balance System,自动平衡系统) ASMO(Advanced Storage Magneto-Optical,增强形光学内存) AST(Average Seek time,平均寻道时间) ATA(AT Attachment,AT扩展型) ATOMM(Advanced super Thin-layer and high-Output Metal Media,增强形超薄高速金属媒体) bps(bit per second,位/秒) CSS(Common Command Set,通用指令集) DMA(Direct Memory Access,直接内存存取) DVD(Digital Video Disk,数字视频光盘) EIDE(enhanced Integrated Drive Electronics,增强形电子集成驱动器) FAT(File Allocation Tables,文件分配表) FDBM(Fluid dynamic bearing motors,液态轴承马达) FDC(Floppy Disk Controller,软盘驱动器控制装置) FDD(Floppy Disk Driver,软盘驱动器) GMR(giant magnetoresistive,巨型磁阻) HDA(head disk assembly,磁头集合) HiFD(high-capacity floppy disk,高容量软盘) IDE(Integrated Drive Electronics,电子集成驱动器) LBA(Logical Block Addressing,逻辑块寻址) MBR(Master Boot Record,主引导记录) MTBF(Mean Time Before Failure,平均故障时间) PIO(Programmed Input Output,可编程输入输出模式) PRML(Partial Response Maximum Likelihood,最大可能部分反应,用于提高磁盘读写传输率) RPM(Rotation Per Minute,转/分) RSD(Removable Storage Device,移动式存储设备) SCSI(Small Computer System Interface,小型计算机系统接口) SCMA(SCSI Configured Auto Magically,SCSI自动配置) S.M.A.R.T.(Self-Monitoring, Analysis and Reporting Technology,自动监测、分析和报告技术) SPS(Shock Protection System,抗震保护系统) Ultra DMA(Ultra Direct Memory Access,超高速直接内存存取) LVD(Low Voltage Differential) Seagate硬盘技术 DiscWizard(磁盘控制软件) DST(Drive Self Test,磁盘自检程序) SeaShield(防静电防撞击外壳)
8、光驱 ATAPI(AT Attachment Packet Interface) BCF(Boot Catalog File,启动目录文件) BIF(Boot Image File,启动映射档) CDR(CD Recordable,可记录光盘) CD-ROM/XA(CD-ROM eXtended Architecture,只读光盘增强形架构) CDRW(CD-Rewritable,可重复刻录光盘) CLV(Constant Linear Velocity,恒定线速度) DAE(digital Audio Extraction,资料音频抓取) DDSS(Double Dynamic Suspension System,双悬浮动态减震系统) DDSS II(Double Dynamic Suspension System II,第二代双层动力悬吊系统) PCAV(Part Constant Angular Velocity,部分恒定角速度) VCD(Video CD,视频CD)
9、打印机 AAS(Automatic Area Seagment?) dpi(dot per inch,每英寸的打印像素) ECP(Extended Capabilities Port,延长能力埠) EPP(Enhanced Parallel Port,增强形并行接口) IPP(Internet Printing Protocol,因特网打印协议) ppm(paper per minute,页/分) SPP(Standard Parallel Port,标准并行口) TET(Text Enhanced Technology,文本增强技术) USBDCDPD(Universal Serial Bus Device Class Definition for Printing Devices,打印设备的通用串行总线级标准) VD(Variable Dot,变点式打印)
10、扫描仪 TWAIN(Toolkit Without An Interesting Name,协议)
11、计算机公司 Ali(Acer Lab,宏基实验室) ASF(Applied Science Fiction,?) AMD: Advanced Micro Device(超微半导体) AMI(American Megatrends Incorporated,?) EAR(Extreme Audio Reality,?) HP(Hewlett-Packard,美国惠普公司) IBM(International Business Machine,国际商业机器) IDG(International Data Group,国际资料集团) IMS(International Meta System,?) MLE(Microsoft Learning and Entertainment,微软教学与娱乐公司) MS(Microsoft,微软) NAI(Network Associates Incorporation,前身为McAfee) NS(National Semiconductor,国家半导体) PMI(Pacific Magtron International) SCE(sony computer entertainment,索尼计算机娱乐部) SGI(Silicon Graphics,?) SiS(Silicon Integrated Systems,硅片综合系统公司) UMC(United Microelectronics Corporation,台湾联华电子公司,半导体制造商) WD(Western Digital,西部数据) ZD(Ziff-Davis出版公司)
12、组织 CBF(Cable Broadband Forum,电缆宽带论坛) CEMA(Consumer Electronics Manufacturing Association,消费者电子制造业协会) CPE(Customer Premise Equipment,用户预定设备) CSA(Canadian Standards Association,加拿大标准协会) DCA(Defense Communication Agency,国防部通信局) DOJ(Department of Justice,反不正当竞争部门) DSP(Delivery Service Partner,交付服务合伙人) DVB(Digital Video Broadcasting,数位视频广播) E3(Electronic Entertainment Expo,电子娱乐展览会) EFF: Electronic Frontier Foundation(电子前线基金会) EPA(Environmental Protection Agency,美国环境保护局) FCC(Federal Communications Commission,联邦通信委员会) FTC(Federal Trade Commission,联邦商业委员会) GDC(Game Developer Conference,游戏发展商会议) ISSCC(International Solid-State Circuits Conference,国际晶体管电路讨论会) ICSA(International Computer Security Association,国际计算机安全协会,它的前身为NCSA(National Computer Security Association,国家计算机安全协会) IEEE(Institute of Electrical and Electronics Engineers,电子电路工程师协会) IFWP(International Forum White Paper,国际白皮书论坛) ISO/MPEG(International Standard Organization's Moving Picture Expert Group,国际标准化组织的活动图片专家组) ITAA(Information Technology Association of American,美国信息技术协会) MAC(Mobile Advisory Council,?) MCSP(Microsoft Certified Solution Providers,微软认证解决方案供货商) MJPEG(Motion Joint Photographic Experts Group,移动式连续图像专家组) MMA(MIDI Manufacturer Association,MIDI制造商联盟) NCTA(National Cable Television Association,美国电缆电视协会) NIA(Networking Interoperatility Alliance,网络互操作联盟) NBITD(National Board for Industrual and Technical Development,瑞典国立工业和技术发展委员会制订) OAAF(Open Arcade Architecture Forum,开放式Arcade体系论坛) OEM(Original Equipment Manufacturer,原始设备制造商) OIF(Optical Internetworking Forum,光纤互连网络论坛) RIAA(Recording Industry Association of America,美国唱片工业协会) RIO(Redistributed Internet Object,因特网分配组织) SIA(The Semiconductor Industries Association,半导体工业协会) SPA(Software Publishers Association,软件出版商协会) TSOWU(The Swedish office worker's union,瑞典办公人员联合会,以制订TCO标准著称) UAWG(Universal ADSL Working Group,通用ADSL工作组) UCAID(University Corporation for Advanced Internet Development,?) UL(Underwriters Laboratories Inc.,新产品承诺实验室) VAR(Value Added Resellers,增值分销商) W3C(World Wide Web Consortium,万维网协会) WHQL(Microsoft Windows Hardware Quality Lab,微软公司窗口硬件质量实验室) WinHEC(Windows Hardware Engineering Conference,窗口硬件工程会议
13、编程 API(Application Programming Interfaces,应用程序接口) ASCII(American Standard Code for Information Interchange,美国国家标准信息交换代码) ATL(ActiveX Template Library,ActiveX范本库) BASIC(Beginner's All-purpose Symbolic Instruction Code,初学者通用指令代码) COM(Component Object Model,组件对象模式) DNA(Distributed Internet Application,分布式因特网应用程序) MFC(Microsoft Foundation Classes,微软基础类库) SDK(Software Development Kit,软件开发工具包)
14、Windows CE(Consumer Electronics,消费电子) DCOM(Distributing Component Object Model,构造物体模块) DHCP(Dynamic Host Configuration Protocol,动态主机分配协议) DMF(Distribution Media Format,?) GDI(Graphics Device Interface,图形设备接口) GUI(Graphics User Interface,图形用户接口) GPF(General protect fault,一般保护性错误) HTA(HyperText Application,超文本应用程序) INF File(Information File,信息文件) INI File(Initialization File,初始化文件) NDIS(Network Driver Interface Specification,网络驱动程序接口规范) NT(New Technology,新技术) Qos(Quality of Service,服务质量) RRVP(Resource ReserVation Protocol,资源保留协议) RTOS(Real Time Operating Systems,实时操作系统) SBFS(Simple Boot Flag Specification,简单引导标记规范) VEFAT(Virtual File Allocation Table,虚拟文件分配表) VxD(Virtual device drivers,虚拟设备驱动程序) WDM(Windows Driver Model,窗口驱动程序模块) Winsock(Windows Socket,窗口套接口) WHQL(Windows Hardware Quality Labs,Windows硬件质量实验室) WHS(Windows Scripting Host,窗口脚本程序) ZAM(Zero Administration for Windows,零管理窗口系统)
15、加密 ECC(Elliptic Curve Crypto,椭圆曲线加密) SET(Secure Electronic Transaction,安全电子交易)
16、语言 CSS(Cascading Style Sheets,层迭格式表) DCD(Document Content Description for XML: XML档内容描述) DTD(Document Type Definition,档类型定义) HTML(HyperText Markup Language,超文本标记语言) JVM(Java Virtual Machine, Java虚拟机) OJI(Open Java VM Interface,开放JAVA虚拟机界面) SGML(Standard Generalized Markup Language,标准通用标记语言) SMIL(Synchronous Multimedia Integrate Language,同步多媒体集成语言) VRML(Virtual Reality Makeup Language,虚拟现实结构化语言) VXML(Voice eXtensible Markup Language,语音扩展标记语言) XML(Extensible Markup Language,可扩展标记语言) XSL(Extensible Style Sheet Language,可扩展设计语言)
17、网络 ADSL(Asymmetric Digital Subscriber Line,不对称数位订阅线路) AH(Authentication Header,鉴定文件头) AMR(Audio/Modem Riser,音效/数据主机板附加直立插卡) ARP(Address Resolution Protocol,地址解析协议) ATM(Asynchronous Transfer Mode,异步传输模式) BOD(Bandwidth On Demand,弹性带宽运用) CBR(Committed Burst Rate,约定突发速率) CCIRN(Coordinating Committee for Intercontinental Research Networking,洲际研究网络协调委员会) CCM(Call Control Manager,拨号控制管理) CDSL(Consumer Digital Subscriber Line,消费者数位订阅线路) CGI(Common Gateway Interface,通用网关接口) CIEA(Commercial Internet Exchange Association,商业因特网交易协会) CIR(Committed Infomation Rate,约定信息速率) CTS(Clear to Send,清除发送) DBS-PC(Direct Broadcast Satellite PC,人造卫星直接广播式PC) DCE(Data Circuit Terminal Equipment,数据通信设备) DES(Data Encryption Standard,数据加密标准) DMT(Discrete Multi - Tone,不连续多基频模式) DNS(Domain Name System,域名系统) DOCSIS(Data Over Cable Service Interface Specifications,线缆服务接口数据规格) DTE(Data Terminal Equipment,数据终端设备) EBR(Excess Burst Rate,超额突发速率) ESP(Encapsulating Security Payload,压缩安全有效载荷) FDM(Frequency Division Multi,频率分离) FRICC(Federal Research Internet Coordinating Committee,联邦调查因特网协调委员会) FTP(File Transfer Protocol,文件传输协议) Ghost(General Hardware Oriented System Transfer,全面硬件导向系统转移) HDSL(High bit rate DSL,高比特率数位订阅线路) HTTP(HyperText Transfer Protocol,超文本传输协议) ICMP(Internet Control Message Protocol,因特网信息控制协议) IETF(Internet Engineering Task Framework,因特网工程任务组) IKE(Internet Key Exchange,因特网密钥交换协议) IMAP4(Internet Message Access Protocol Version 4,第四版因特网信息存取协议) Internet(因特网) IP(Internet Protocol,网际协议) ISDN(Integrated Service Digital Network,综合服务数字网络) ISOC(Internet Society,因特网协会) ISP(Internet Service Provider,因特网服务提供商) LAN(Local Area Network,局域网) LDAP(Lightweight Directory Access Protocol,轻权目录访问协议) LOM(LAN-on-Montherboard) IAB(Internet Activities Board,因特网工作委员会) IETF(Internet Engineering Task Force,因特网工程作业推动) L2TP(Layer 2 Tunneling Protocol,二级信道协议) LMDS(Local Multipoint Distributed System,局域多点分布式系统) MIME(Multipurpose Internet Mail Extension,多用途因特网邮件扩展协议) MNP(Microcom Networking Protocal) MODEM(Modulator Demodulator,调制解调器) NAT(Network Address Translation,网络地址转换) NC(Network Computer,网络计算机) NDS(Novell Directory Service,Novell目录服务) NNTP(Network News Transfer Protocol,网络新闻传输协议) MSN(Microsoft Network,微软网络) OFDM(orthogonal frequency division multiplexing,直角频率部分多任务) P3P(Privacy Preference Project,个人私隐安全平台) PDS(Public Directory Support,公众目录支持) PGP(Pretty Good Privacy,优良保密协议) PICS(Platform for Internet Content Selection,因特网内容选择平台) POF(Polymer Optical Fiber,聚合体光纤) POP3(Post Office Protocol Version 3,第三版电子邮局协议) PPTP(Point to Point Tunneling Protocol,点对点信道协议) RADSL(Rate Adaptive DSL,速率自适应数字订阅线路) RARP(Reverse Address Resolution Protocol,反向地址解析协议) RDF(Resource Description Framework,资源描述框架) RSA(Rivest Shamir Adlemen,一种因特网加密和认证体系) RTS(Request To Send,需求发送) SIS(Switched Internetworking Services,交换式网络互联服务) S/MIME(Secure MIME,安全多用途因特网邮件扩展协议) SNMP(Simple Network Management Protocol,简单网络管理协议) SMTP(Simple Mail Transfer Protocol,简单邮件传输协议) SKIP(Simple Key Exchange Internet Protocol,因特网简单密钥交换协议) SUA(Single User Account,单用户账号) TCP(Transmission Control Protocol,传输控制协议) UDP(User Datagram Protocol,用户数据报协议) ULS(User Location Service,用户定位服务) VOD(Video On Demand,视频点播) VPN(virtual private network, 虚拟局域网) WWW(World Wide Web,万维网,是因特网的一部分)
18、通信 CTI(Computer Telephone Integration,计算机电话综合技术) DBS(Direct Broadcast Satellite,直接卫星广播) DWDM(Dense WaveLength Division Multiplex,波长密集型复用技术) MMDS(Multichannel Multipoint Distribution Service,多波段多点分发服务) PCM(Pulse Code Modulation,脉冲编码调制) PSTN(Public Switched Telephone Network,公用交换式电话网) TAPI(Telephony Application Programming Interface,电话应用程序接口) TSAPI(Telephony Services Application Programming Interface,电话服务应用程序接口) WDM(WaveLength Division Multiplex,波分多任务)
19、游戏 ACT(Action,动作类游戏) ARPG(Action Role Play Games,动作角色扮演游戏) AVG(Adventure Genre,冒险类游戏) DAN(Dance,跳舞类游戏,包括跳舞机、吉它机、打鼓机等) DC(Dreamcast,世嘉64位游戏机) ETC(etc,其它类游戏,包括模拟飞行) FFJ(Force Feedback Joystick,力量反匮式操纵杆) FPP(First Person Game,第一人称游戏) FTG(Fighting Game,格斗类游戏) GB(Game Boy,任天堂4位手提游戏机) GBC(Game Boy Color,任天堂手提16色游戏机) GG(Game Gear,世嘉彩色手提游戏机) FC(Famicom,任天堂8位游戏机) fps(frames per second,帧/秒) FR(Frames Rate,游戏运行帧数) MAC(Macintosh,苹果计算机) N64(Nintendo 64,任天堂64位游戏机) SFC(Super Famicom,超级任天堂16位游戏机) SLG(Simulation Game,模拟类游戏) SPG(Sports Games,运动类游戏) SRPG(Strategies Role Play Games,战略角色扮演游戏) STG(Shoot Game,射击类游戏) SS(Sega Saturn,世嘉土星32位游戏机) PC(Personal Computer,个人计算机) PS(Play Station,索尼32位游戏机) PS(Pocket Station,索尼手提游戏机) RAC(race,赛车类游戏) RTS(Real Time Strategies,实时战略) RPG(Role Play Games,角色扮演游戏) TAB(Table Chess,桌棋类游戏)
20、服务器 C2C(card-to-card interleaving,卡到卡交错存取) cc-NUMA(cache-coherent non uniform memory access,连贯缓冲非统一内存寻址) CHRP(Common Hardware Reference Platform,共享硬件平台,IBM为PowerPC制定的标准,可以兼容Mac OS, Windows NT, Solaris, OS/2, Linux和AIX等多种操作系统) EMP(Emergency Management Port,紧急事件管理埠) ICMB(Inter-Chassis Management Bus, 内部管理总线) MPP(Massive Parallel Processing,巨量平行处理架构) MUX(Data Path Multiplexor,多重路径数据访问) SOS(Server Operating Systems,服务器操作系统) TPS(transactions per second,每秒处理事项数) UPA(Ultra Port Architecture,超级端口结构)
21、其它 AL(Artificial Life,人工生命) APM(Advanced Power Management,高级能源管理) AVI(Audio Video Interleave,音频视频插入) ASPI(Advanced SCSI Program Interface, 高级SCSI编程界面。它定义了当和SCSI主机适配器通讯时应用程序使用的一系列软件命令) Benchmarks(基准测试程序数值) BOPS(Billion Operations Per Second,十亿次运算/秒) BSD(Berkeley Software Distribution,伯克利软件分配代号) CAD(computer-aided design,计算机辅助设计) CCD(Charge Coupled Device,电荷连接设备) CCS(Cut Change System) COMDEX (Computer Distribution Exposition,计算机代理分销业展览会) CEO(Chief Executive Officer,首席执行官) COO(Chief Organizer Officer,首席管理官) CTO(Chief Technology Officer,首席技术官) CTS(Carpal Tunnel Sydrome,计算机腕管综合症) CPS(Certification Practice Statement,使用证明书) CVS(Compute Visual Syndrome,计算机视觉综合症) DAC(Dual Address Cycle,双重地址周期) DPC(Desktop PC,桌面PC) DSL(Data Strobe Link,数据选通连接) ERP(Enterprise Requirement Planning,企业需求计划) ERP(estimated retail price,估计零售价) ES(Energy Star,能源之星) FAQ(Frequently Asked Questions,常见问题回答) GPS(Global Positioning System,全球定位系统) HCI(Host Controller Interface,主机控制接口) HCT(Hardware Compatibility Test,硬件兼容性测试) HPS(High Performance Server,高性能服务器) HPW(High Performance Workstation,高性能工作站) IHVs(Independent Hardware Vendors,独立硬件购买者) IRQ(Interrupt Request,中断请求) ISVs(Independent Software Vendors,独立软件购买者) JIT(Just In Time,准时制生产) MFD(Multi Function Device,多功能设备) MIPS(Million Instruction Per Second,百万条指令/秒) MMVF(Multi-Media Video File,多媒体视频文件) MRP(Material Requirement Planning,物料需求计划) MRP II(Manufacturing Resource Planning,制造资源计划) MRS(Midrange Server,中型服务器) MRW(Midrange Workststion,中型工作站) MSP(Media Stream Processor,媒体流处理器) MTVPAK(Microsoft TV Platform Adaptation Kit,微软TV平台适配套件) OPT(Optimized Production Technology,优化生产技术) PIC(Programmable Interrupt Controller,可编程中断控制器) PIM(Personal Information Management,个人信息管理系统) PNP(Plug and Play,即插即用) PSU(Power Supply Unit,计算机电源) REMA(Realtime Exclusive Mode Applications,实时高级应用) RF(Radio Frequency,无线电频率) SAM(sales available market,可发售市场) SCT(Software Compatibility Test,软件兼容性测试) SMD(Surface Mount Device,表面安装设备) SMM(System Management Mode,系统管理模式) SMP(GSymmetic Multi-Processor) SOAC(System On a Chip,系统集成多功能芯片) STB(Set Top Boxes,顶置盒) TCO(Total Cost of Ownership,拥有总成本) TSID( Technical Support Identification Number,技术支持代码) TTL(Transistor-Transistor Logic,晶体管to晶体管逻辑电路) TQM(Total Quality Management,全面质量管理) VBI(Vertical Blanking Interval,垂直空白间隔) WfM(Wired for Management,有线管理) WMI(Wired for Management Initiative,主动式管理线路) WOL(Wake On Lan,局域网唤醒)
